Carrier board connector
Hi, when will carrier boards go on sale? & what connector do I need to mount on a carrier board? Is it AXK5S00047YG? Unfortunately I can't find a place to buy 10 or so of those connectors, as Mouser/DigiKey only sell them per 1500 on a reel, which is a few too many for my use case. Thanks!
Hi Rubynerd,
The board to board connector is Panasonic. AXK6S00647YG
The UP-core is male connector, you will need a matching female connector with the same part number. -
Hi - which pitch? https://www.panasonic-electric-works.com/pew/eu/downloads/ds_p5k_p5ks_en.pdf shows multiple pitches with the same part number you've provided.
Hi Rubynerd,
The pitch is 0.5 mm
Sorry, I meant mated height - the pitch is always 0.5mm.
Additionally, do you know if the other mated heights are cross-compatible with the connector on the UP Core?
Hi rubynerd,
We are using 5.3mm height on the UP core, as long as it is Panasonic. AXK6S00647YG, the mating height can be compatible.
Amazing - it's basically impossible to get these connectors without buying a reel, but someone on eBay apparently has some, so I'll get some of those and see how I go with them
Digi-Key P/N: 255-4198-1-ND
- 3.5K UP Products
- 23 UP 7000
- 15 UP Squared Pro 7000
- 24 UP Xtreme i11
- 141 UP Xtreme
- 223 UP Core
