[SOLVED] Got my UP 2 board today. But can't boot any thing on it.
Raymond Day
Raymond Day New Member Posts: 67 ✭
All it does it goes in a EFI Shell!
I downloaded from this web site the ubuntu-16.04.2-desktop-amd64.iso burn it to a DVD and plug in a USB DVD drive with 2 USB to power it good.
It spins but still just goes in the EFI Shell.
What can I type to install it in this EFI Shell?
-Raymond Day
SOLUTION:
press F7 and then I could pick to install from the USB and it's installing now.
  • Michael Miller
    Are you able to make a bootable USB stick? that is how I installed windows.
    Hi Raymond,
    Can you try to flash the ubuntu 16.04.2 iso to a USB stick and boot from USB?
    Also please check from the BIOS boot menu that the USB device is recognised as UEFI bootable device.
  • Raymond Day
    I downloaded "ubuntu-16.04.2-server-amd64.iso" used Win32Diskimager to put it on a 32GB USB stick.
    Put that stick in the USB on the back of the Up2 board. But still just boots up to the yellow "Shell> _" for me to type something.
    After about 1 minute if I don't type the screen goes blank and I can't get it back hitting any keys or moving the mouse. I have to do a Ctrl, Alt, Del on the keyboard
    Comes up "EFI Shell version 2.50 {5.12}"
    "Device mapping table
    fs1
    blk0
    blk1
    blk2
    blk3
    blk4
    blk5
    Press ESC in 1 seconds to skip startup.nsh any other key to continue."
    Then all I can do it type.
    I typed /boot/blk0 to blk1 but it don't work.
    -Raymond Day
    Hi Raymond,
    Please keep the USB stick inserted into UP^2 while performing the following steps.
    when you boot the board, could you press DEL to enter the BIOS while the AAEON logo shows up?
    Just press enter once prompted for password and then move to Boot menu.
    What are the options available there?
  • Raymond Day
    Looked on Google and came to a link here:
    https://up-community.org/forum/general-discussion-up/1209-up-board-out-of-the-box-booting-directly-to-efi-shell
    It said press F7 and I did and then I could pick to install from the USB and it's installing now.
    -Raymond Day
    very good!
    Another way is to enter in the BIOS menu and then move to the boot menu, but pressing F7 is easier ;)
  • monteroluiyi
    monteroluiyi New Member Posts: 1 ✭
    Buenas noches, yo estoy presentando el mismo problemas mi computadora de respete se apagó y sale ese mismo problemas y no puedo solucionarlo
