Up Xtreme fallback to UEFI shell on cold boot
I use several Up Xtreme for industrial projects but on one system, if I do not use it for several days, on the first boot, the Up does not boot properly and stop in the UEFI shell. If I unplug the power and try again, it works and I can power cycle it again in the same day.
But as soon I let it off for a few days, the problem happen again.
But in my industrial process, I need to make it boot automatically with a relay and there is no screen connected in case of a failure.
Do you have an idea how to fix this behavior?
This is a picture of a failed boot with a screen connected:
Edit: I have already tried to upgrade the BIOS version to the latest available but with no success.
Hi @rreignier ,
I suspect it is from the CMOS battery. Can you check in BIOS when this happens if the date and time resets?
Hi @camillus
I had the same though but after a reboot, without any internet connection for more than 2 weeks, the date and time in BIOS are still up to date.
And the BIOS setting to always power on after a power failure is still set.
So I guess the issue might be elsewhere. -
@rreignier said:
Hi @camillusI had the same though but after a reboot, without any internet connection for more than 2 weeks, the date and time in BIOS are still up to date.
@camillus I think that there is an issue on my board, how should I apply for RMA?
Hi @rreignier ,
You can apply for an RMA from here if you purchased directly from UP shop, otherwise you have to raise it through your reseller.
- 292 All Categories
- 104 Announcements & News
- 181 Welcome Developers!
- 20 Tech Updates
- 412 UP Products
- UP 4000
- 12 UP Xtreme i11
- 21 UP Squared 6000
- 40 UP Squared Pro
- 132 UP Xtreme
- 797 UP Squared
- 86 UP Core Plus
- 41 UP AI Edge
