ISP cable to connect UP Squared pack-APLC2-0432 with DediProg SF-600
I have the UP Squared pack-APLC2-0432. Where can I find the cable to connect it with the DediProg SF-600?
The one from SF-600 is ISP Cable (ISP-600-CB1-G) . But it does not fit with connection of the UP Squared pack.
Canh
From this webpage
https://wiki.up-community.org/BIOS_chip_flashing_on_UP_Squared, we have the following line
"Procedure
First, make sure you have made a custom cable to connect SF100 and UP Squared CN22 connector. "
Where can I buy that custom cable? or do I have to make it ?
Canh
Hi @ctkha
It is a cable we do internally.
We are checking if it is something we can provide in our shop or, if not possible, provide you the details of the connectors for you to build it.
Hi DCleri,
Could you give an update for this issue?
Canh
