external flasher for RE-UP-CHT01-A10-0116
New Member Posts: 1
we are planning to set up a class on linuxboot at the next OCP summit in March. The UP board is a near-perfect board, but we need the ability to reflash from an external programmer. There is a mention of this in the manual but I'm not sure which connector/pins are the right ones to use, and, further, what voltage is needed. Finally, are there schematics anywhere?
Thanks.
Welcome!
Welcome!
