No UP Splash Screen and can't access BIOS
Hi!
I've installed Ubuntu 18.04 on my UP board and installed and configured RDP. Since then the splash screen hasn't been showing up nor can I see the BIOS. I know it's still there because I can press F7 to get in to boot menu and select a bootable USB (only because I know how many times to press the down arrow).
I've tried reinstalling Ubuntu and that hasn't worked, as well as unplugging the CMOS battery for about 2 minutes (just in case!)
Does anyone have any suggestions?
I don't think that RDP can change the board behavior, so it is really strange what you are describing.
About RDP setup, can you please provide your setup (hardware and software) and RDP setup and configuration so we can try to replicate the behavior?
Can you access the BIOS menu (not the boot menu) pressing delete? can you navigate and use it normally?
In case something else caused the BIOS screen/menu to stop showing, you can try to update/reflash your BIOS in case it got corrupted for any other reasons.
Hi DCleri,
I don't think it was my RDP setup in the end. I left the UP board unplugged (after reinstalling ubuntu 18.04), but I can't remember how long for, then the splash screen magically returned! But once again it has gone on its own volition and now I can't boot into an ubuntu bootable drive to reinstall again.
I can't access BIOS either, I just have a blank screen. I know the keyboard is connected because num lock is lit up.
How would I go about updating my BIOS if I can't tell where I am in the boot menu? -
I would suggest you to request for RMA from the up-shop (or a distributor if you got it from somewhere else) so that we can check what is happening on this board
- 70 Product News - New Product/Product Change Notice/ End-of-life
- 3.5K UP Products
- 23 UP 7000
- 15 UP Squared Pro 7000
- 24 UP Xtreme i11
- 141 UP Xtreme
- 223 UP Core
