[SOLVED] BIOS Upgrade. Windows 10
aivision
aivision New Member Posts: 12 ✭
edited August 2019 in UP board BIOS
Hello, I would like to know how to upgrade the BIOS. Some links are broken and, when entering into the currect BIOS, I can't see any option for EFI update or others.
UP is running on W10 Pro. Thank you
    What UP Board do you have exactly?
    Have you downloaded the right BIOS for your board and added to a USB stick, booting from there as described in the wiki?
    https://wiki.up-community.org/Bios_Update#Procedure
  • aivision
    edited August 2019
    I followed the procedure as described. First I'd got an error as "Error: Secure Flash function is not supported on this file".
    However, following this workaround post, I saw that BIOS v17 is not compatible and I installed v15 successfully.
    After that, when I try to install the current drivers from the download area, an error as "The requested operation failed, A system reboot is required to roll back changes made" lets the installation fail.
    Before posting the error log that is generated, I would like to know if the current drivers are compatible with BIOS v15.
    I have several UPs, but the one that I use here is a 4GB RAM and 32GB eMMC and probably it is one of the first that I purchased a couple of years or more ago.
    Update: I solved it following this post. The key is to remove spaces of the folder name.
    Thanks @DCleri and UpCommunity!
