S.USV UPS hat's new firmware 2.60 is not functional with old Ubilinux susvd 2.4 on Ubuntu 18.04
Cyanryaku
Cyanryaku New Member Posts: 4 ✭
I found the i2c interface cannot query correct voltage-in value and turn on/off charging circuit proactively after upgraded to firmware 2.6. Then I downgraded the firmware to 2.4 and it seems to work again.
I am using LiPo 300mA battery with slow charging current 300mA settings.
  • ccalde
    Hi @Cyanryaku ,
    Could you please drop more info about the question?
    What is exactly your setup there?
    What firmware and OS are you using?
    What steps did you follow to get the issue?
