[SOLVED] GPIO on up2 board doesn't respond
Mondo
Mondo New Member Posts: 4 ✭
edited July 2019 in UP Board Linux
I have an up2 board (8 GB RAM, 64GB eMMC). I folow an exmaple described here https://wiki.up-community.org/Pinout_UP2#GPIO trying to blink one of bard's LEDs. However nothing blinks, what is the problem?
My Kernel version is: 4.15.0-29-generic
OS: Ubuntu
All patchs like /sys/class/gpio (the one from example) are there so I assumed the kernel is ok right?
In case the kernel is wrong, do you have any guide how to write module for this GPIO to control it?
  • Mondo
    edited April 2019
    Ok I installed different kernel, namely linux-image-generic-hwe-18.04-upboard and it works now as expected. Now, I would like to play a bit with it and as a first step I would like to write a driver for these gpio pins. Where can I find a guide, docuemntation & source code of the driver?
  • ccalde
    Hi @Mondo
    From your UP board, once you have installed the UP specific Ubuntu Kernel 4.15: https://wiki.up-community.org/Ubuntu
    sudo apt-get source linux-hwe
    There you will get the source code for the driver.
