USB 2.0 port compatible connector??
Hi. I need to use 2 USB 2.0 port and UART0 of Upsquared board. But i didn't find any compatible connector on Digikey and farnell?? if i dont find any compatible connector . i will dissasemble connector and solder the wire instead of connector
(there are compatible cable on Up Shop but shipping time long for me)
manufacturer:CATCH manufacturer part number : 1204-700-10RM
ftp://data.aaeon.com.tw/DOWNLOAD/testreport/ULVENDOR/COM-BYTC2-A10-0001.pdf
The USB2 port connector looks like it is compatible with the JST SH series.
Available from RS components:
Connector: https://uk.rs-online.com/web/p/crimp-terminal-covers/3116552
Pre-crimped wires: https://uk.rs-online.com/web/p/pcb-connector-contacts/3116675Gaz
As I'm not in the USA I'm trying to find a cheaper alternative to buying Up's USB cable. This cable would work wouldn't it?
https://www.delock.com/produkte/S_84833/merkmale.html
Not sure if I'd have to file off the lip but no big deal.
Fidelity,
the Delock cable seems to have a connector with 1.25mm pitch. If true, this would not work with the board (which requires 1mm pitch connector).By any means, buy pre-crimped wires with JST SH connector. I was stupid enough to buy connectors and wire that I had to crimp myself (BIG mistake).
