[SOLVED] RPI HAT compatibility
Will work in up board those e-ink displays and sensors and HAT for RPI? Can you please, as I'm a beginner , what I need to make the work? Recompile the kernel or just install drivers. Last, can I follow the tutorials for rpi to install that drivers?
Hi @FPSychotic ,
First at all, I would recommend you to download the hardware specifications for UP board:
https://downloads.up-community.org
Then, check the compatibility with your RPI hardware like pinout, power, etc.Also, you should install Ubuntu 16 with the official 4.15 kernel for UP:
https://wiki.up-community.org/Ubuntu#Install_Ubuntu_kernel_4.15.0_for_UP_from_PPA
And you could get the drivers used by your RPI hardware and check if they are available in the UP kernel. -
Thanks a lot for your answers is very diffult start in this hobby XD.
Just one question more, is possible install the 4.15 kernel and recompiling it with modules or drivers (I dont know exactly what is the difference) that are not buildt in from default?
Again, thanks by your time. -
Hi @FPSychotic ,
From Launchpad, you will get the kernel integrated with upboard modules, ready to working on board.
If you want to get the kernel and recompile it with new changes, you could donwload the sources files and build locally in your side:
https://launchpad.net/~ubilinux/+archive/ubuntu/up/+sourcepub/9208269/+listing-archive-extraSearch for the linux-hwe_4.10.0-42.5000~upboard11.tar.gz package. It would be enough to recompile the kernel.
