Wifi Dongle - iwconfig - Operation not permitted
I'm trying to use a wifi dongle to connect my Up-Board to my network. But I'm getting stuck. I'm running ubilinux. This is what I've done so far.
When I run:
sudo ifconfig -a
The dongle shows up as:
wlx503eaa88648a: flags=4098<BROADCAST,MULTICAST> mtu 1500 ether 50:3e:aa:88:64:8a txqueuelen 1000 (Ethernet) RX packets 0 bytes 0 (0.0 B) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 0 bytes 0 (0.0 B) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
When I run:
lsusb
The device shows up as:
Bus 001 Device 006: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
I installed wireless tool using:
sudo apt-get install wireless-tools
I tried to add my network using:
sudo iwconfig wlx503eaa88648a essid MyNetworkName key s:MyNetworkPassword
But this results in:
Error for wireless request "Set ESSID" (8B1A) :
SET failed on device wlx503eaa88648a ; Operation not permitted.
Any suggestions would be greatly appreciated!
I managed to get this running. For reference, this is what I did to fix it. (Apologies if I missed a step.) First I ran the following:
sudo ifconfig # Shows only active devices sudo ifconfig -a # Shows all devices
The wifi dongle only showed up with the second one, which altered me to the fact that I needed to enable the device which I did with:
sudo ifconfig [device reference] up
In my case the device reference starts with wlx. Next I added the network info to the file /etc/wpa_supplicant.conf
network={ ssid="[networkName]" psk="[password]" }
I started the WPA connection with:
sudo wpa_supplicant -B -i [device reference] -c /etc/wpa_supplicant.conf -D wext
When I ran 'sudo route -t' I noticed there was no default gateway specified, which I added using (not sure both are needed):
sudo /sbin/ifconfig [device reference] [desired ip] netmask 255.255.255.0 broadcast 192.168.1.255 sudo route add default gw [router ip] [device reference]
The desired ip can be chosen. My ethernet ip is usually 10.0.0.19 so I choose 10.0.0.29, as I find it easy to remember.
Finally I ping my router to see if the connection is established:
sudo ping -c 3 [router ip]
For the moment I've set this up as a script that runs after boot.
Here are some threads that I found useful:
https://askubuntu.com/questions/138472/how-do-i-connect-to-a-wpa-wifi-network-using-the-command-line
Hi @MatAff ,
Thank you so much for sharing the info
