not able to WOL up2
Marian
New Member Posts: 16 ✭
I am not able to wake on lan my up2.
I have no problem with 2 up board, I am able to wake them both, however I am failing to wake up up2.
Do you have any clue what could be issue?
I have reset the board to factory default already, so far no luck.
SOLVED
problem was that I am running debian on up boards, while centos on up2
it seems that debian enable it by default while on centos I had to enable it myself, below command solved itethtool -s {device} wol g
UPDATE
to make it permanent you have to add line below to /etc/sysconfig/network-scripts/ifcfg-{device}
ETHTOOL_OPTS="-s ${DEVICE} wol g"
just make sure you have specified the "DEVICE" inside the config file
