can i flash kickstarter version of up squared with newest bios?
and if yes would it solve my emmc problem described below?
To resolve the 128 eMMC timeout issue, a setting in the BIOS needs to be adjusted
In the BIOS menu under Chipset, please adjust the eMMC Max Speed from HS400 to DDR50
The reason for this is because the 128GB eMMC is from SanDisk, and the flash controller that SanDisk uses require the Speed to be DDR50, the end result is a slower eMMC read/write performance comparing to other brands such as Hynix or Samsung.
We have highlighted this issue to SanDisk and there is no resolution, therefore, we have decided for MP version of UP2, we will use Samsung for the 128GB SKU. We have tested the Samsung 128GB on UP2 and it runs at HS400 (EMMC 5.1) for all different OS such as Windows/Linux/Android.
Best Answer
Hi @Marian
Yes that version is fine to update with latest BIOS.
Hi @Marian
Unfortunately that problem won't be solved by a BIOS update as it is related to the specific eMMC chip.
When did you receive the board?
Hi @Dcleri
june 2017
couple days before opening thread https://forum.up-community.org/discussion/1898/solved-up2-storage-getting-readonly-frequently#latest
So is it safe to flash the bios even it will not fix the emmc issue?
Thanks for the answer in advance.
