Intel RealSense not detected
jfwillaert
jfwillaert New Member Posts: 5
Want to use micro-USB3 for Realsense-intel-3D. Impossible ... Even with this cable https://up-shop.org/up-peripherals/22-usb30-otg-cable.html
an idea ?
  • jfwillaert
    It's like the data transfer function was not activated. Is that possible ?
  • eduncan911
    an idea ?
    Hello and welcome to the forums.
    Can you plug the RealSense directly into one of the USB3 ports?
    Could you also provide more information about your setup?
    • Which Intel RealSense camera do you have?
    • BIOS version on the UP Squared?
    • Reset BIOS to Factory Defaults?
    • What operating system you are trying to use?
    • If windows, what version of the UP drivers did you install?
    • Any other relative information.
    By default BIOS settings, all 3x USB3 ports operate at the full 5 Gbps speed.
    Ps, I also changed the title of your post as it had your email address. "Intel RealSense not detected"
  • jfwillaert
    Hi thank's for your interest. I use RealSense Intel D435 camera. The three USB3 classic are ok.
    I want to use the fourth the micro USB 3 and it don't seem activ.
  • MatAff
    MatAff New Member Posts: 18 ✭✭
    @jfwillaert I've worked with the RealSense camera quite a bit, and I know it's very sensitive to the cable that's being used. (See many posts on the intel RealSense forum)
    I have run a RealSense on the UP board. I used the connector that was provided with the UP board. (The small blue one, I believe it goes from a male 10 pin type B to a female Type A. I then used the original RealSense cable to connect the RealSense.
    As a side note, even though Intel states only the original cable should be used, I did find a replacement cable that works:
    https://www.ntcdistributing.com/usb-3-1-type-c/a-to-c/usb-3-1-a-male-to-c-male-cable/
    Good luck!
  • jfwillaert
    Thank's but for the classic USB3 I don't have problem's ... that's for the micro-USB3 otg ... regards
    jf
