i2c pullups
Trying to integrate the up2 with i2c devices, and running into issues with communication. What are the internal pullups set to on the i2c lines. Where can I set these, or how can they be changed? For a board designed for the maker community this should be basic information that is necessary to utilize it. Unfortunately with no specifications or schematics available, it is nearly impossible to use this board.
Any update here?
Hi!
I have an Up-Board which is similar but not the same to your board. You can measure the external pull-up resistors with a multimeter via resistance metering. You have to disconnect the power supply of the board then connect one of the probes of the multimeter to the 3V3. The other probe has to be connected to the SDA then the SCL pins on the 40-pin header.
In my case the resistance of the external pull-ups are 2k2.
- 105 Announcements & News
- 5.5K Product News - New Product/Product Change Notice/ End-of-life
- 349 Welcome Developers!
- 180 Unboxing & Project Sharing
- 12.9K Tech Updates
- 6.9K UP Products
- 179 UP 7000
- 22 UP Squared i12
- 5.9K UP Xtreme i12
- 34 UP Squared Pro 7000
- 13 UP Element i12 Edge
- 71 UP 4000
- 32 UP Xtreme i11
- 36 UP Squared 6000
- 67 UP Squared Pro
- 174 UP Xtreme
- 847 UP Squared
- 90 UP Core Plus
- 224 UP Core
- 4 UP Xtreme Lite
- 44 UP AI Edge
- 223 Starter Kits & Peripheral
