I2C0 on Upcore and upboard does not work.
I was trying to test if the two I2C ports on upcore are woking but I found out that the I2C1 port works fine when I run "i2cdetect -r 0" but the i2c0 port on pin 73 (I2C0_SOC_SDA ) and 75 (I2C0_SOC_SCL) do not owrk as I tried to probe the SCL line with an oscilloscope.
Interestingly I found these messages in the kernel bootup log:
[ 2.678814] i2c_designware 808622C1:00: failure requesting irq 32: -38
Jan 25 12:52:23 mindmusiclabs kernel: [ 2.686215] i2c_designware 808622C1:00: I2C_DESIGNWARE 0 Controller at 0xa162e000 (irq 32) (baudrate 400000)
Jan 25 12:52:23 mindmusiclabs kernel: [ 2.686261] i2c_designware: probe of 808622C1:00 failed with error -38
I guess the 808622C1:00 instance which is the i2c0 port is not successfully set up.
Note: This is the case with UpBoard also, I have checked on upboard too. the i2c0 doesn't work and same messages are seen in the kernel log.
Please confirm if there is any issue and how to fix it.
-Thanks
Did you ever resolve this? On one board I2C1 periodically does not initialize correctly.
How we can configure the UART TX and RX pin 16 and 18.
They are multi functional pins -
Did you end up resolving this problem? I've also got a similar problem in April 2019 https://forum.up-community.org/discussion/3650/i2cdetect-y-1-failing-with-i2c-designware-808622c1-04-controller-timed-out#latest but there have been no replies.
