UP board heat spreader mounting holes dimensions
Hi, I'm looking for 2d/3d drawings of the heat spreader (not heat sink) for the UP Board. I don't see it at the current community download page, but at some point in the past it was available - I was able to use it to determine the mounting holes positions. Unfortunately I didn't save that file.
Good thing I kept files in my 'Download' folder for years. I found the zip file that contains the .dwg file of the part in question (M16UPCH020).
Can a .STP file be make available as well? The tapered-punch out part of the plate is not trivial to re-create in 3d. Thanks.
Hi, could you repost the DWG file ? I don't seem to find it anywhere and would help me a lot to create a custom plate for the UP.
Thank you! -
For some reasons the forum doesn't let me post the file here, even if it's just a jpg file. I can email to you. Hopefully admin sees this and add their DWG file back into the Download section.
Sure, that would be great !
Thanks a lot ! Meanwhile I have recreated the pattern in direct measurements and I was "about" there. The spacing is a lot more clearer now.
Thank you.
- 105 Announcements & News
- 55 Product News - New Product/Product Change Notice/ End-of-life
- 184 Welcome Developers!
- 55 Unboxing & Project Sharing
- 32 Tech Updates
- 660 UP Products
- 1 UP 7000
- UP Squared i12
- 8 UP Xtreme i12
- 9 UP Squared Pro 7000
- 18 UP Squared V2
- 54 UP 4000
- 24 UP Xtreme i11
- 35 UP Squared 6000
- 58 UP Squared Pro
- 142 UP Xtreme
- 834 UP Squared
- 89 UP Core Plus
- 222 UP Core
- 44 UP AI Edge
- 215 Starter Kits & Peripheral
