Pin length on 40 Pin header
I'm looking to integrate the Up board (UP-CHT01) onto a control PCB. For this, I was hoping to get the pin length of the 40 Pin header, to be clear what I'm asking for, see the following image:
I have found a .step file of the UP board online, from this the pin length is given as ~ 6.3mm, can someone confirm this is correct? Or even better, could someone supply the part number of the header?
