Support for wiringPI
Do you plan to support wiringPi? Up board is trying to be consistent with the Raspberry Pi. I think it would be good to have these libraries on Up Board, because lot of software use them. For example, HK support wiringPi (https://github.com/hardkernel/wiringPi) for ODROID SBC family.
My guess is it would not be hard to port. Note: I have only used this a little bit on my Odroids (C1, C2, Xu3 lite, XU4)
For example I am able to git clone their project. Was able to cd to the build directory and do: sudo make install
And it completed.
If I then go to gpio directory, it does run, but needs fine tuning. For example if you do:
gpio i2cd
It will error out saying:kurt@kurt-UP-CHT01:~/wiringPi/gpio$ gpio i2cd piBoardRev: Unable to determine board revision from /proc/cpuinfo -> No "Revision" line -> You may want to check: -> http://www.raspberrypi.org/phpBB3/viewtopic.php?p=184410#p184410
May play with this later.... May need to fork it. -
I look source on both - original wirinigPi and changes into ODROID branch.
Mapping pins would be easy, but i'm worried about set clocks, registers and pwm modes.
If you want I will try help / co-operate. Right now i'm working on add DSI/LCD support to Linux Kernel -
Long shot, but did you guys get any progress (or start a fork) getting wiringPi to work on Up boards?
I'm hoping to connect up the Matrix Voice board, but it's got a dependency on a working wiringPi
I'd gotten past the error Kurt provided by disabling the various checks in WiringPi's source, but I ended up with a mmap error, mmap (GPIO) operation not permitted
Sorry No,
I have not looked at it since then. I have not been playing with the IO pins on the UP for awhile now. May get back to it soon, as I may change out the RPI3 in my turtlebot 3 waffle PI, with the UP board and Intel camera... But will probably continue using MRAA instead of wiring pi
Thanks @Kurt - I've managed to bodge a version of wiringPi from source to work with the correct pin mappings etc, at least for general GPIO. Not sure how I test SPI particularly, but I've adjusted it to /dev/spidev1.0 etc and it seems to be happy enough.
Hi @odro,
Is that discussion closed? Cloud we define it as RESOLVED? Something like that: [RESOLVED] Support for wiringPI
Cheers!
