SDIO on UP Core
Does the up core support SDIO?
I would like to connect device like Wi-Fi module.
Best Answers
Hi Tomo,
That's correct, but it's dedicated for SD card use. see below information about SDIO interface -
Thank you for SoC information.
I understand.Thank you.
Hi Tomo,
Wi-Fi module for UP CORE has already supported. Please click on the link below for UP CORE Datasheet, and take a look at block diagram
www.up-board.org/wp-content/uploads/2016/05/UP-core-DatasheetV0.3.pdf -
Hi rogertsai,
Thank you for your answer.
I understand UP CORE has already on-board Wi-Fi module.
However, I would like to connect UP CORE to other Wi-Fi module has SDIO interface.
UP CORE seems to have SDIO interface in 100pin docking connector.
Does it work as SDIO host controller that support Wi-Fi module?Thank you.
The 100 pin Docking Connector does not support SDIO, only for SD card
SDIO is written in up-crst01_20171010.pdf.
Is it incorrect?
