ubuntu 16.04.3 doesn't boot up after successful installation on up2 board
sharpriy26sharpriy26 New Member Posts: 3
Hello guys,
I had installed ubuntu 16.04.03 from usb drive on up2 board. It got installed successfully. And after this it gave this message 'Remove installation medium and press enter'. I removed usb drive and pressed enter key.
But ubuntu didn't boot up although it got installed successfully. Could anyone please tell what could be the reason for this?
  • Brian BeukenBrian Beuken New Member Posts: 35
    Did you manage to resolve this? I must say the decision to switch servers and forums so soon after people are getting delivery of these boards is quite worrying.
    I have my Up core running the unbilinux it came with but I'm very unimpressed, its painfully slow (probably only 1 core running).
    I would also like to switch to a different linux but info on the process is either not here or hidden away.
  • nukularnukular New Member Posts: 71 ✭✭✭
    just in case anyone is coming across this thread and is wondering: Ubuntu 16.04.03 LTS is working without problems for me so far. With both the default ubuntu kernel and also with 4.9.45-upboard
  • m0n0m0n0 New Member Posts: 1
    Hi!
    I had a similar problem, I took out the msta drive, restored the bios to the default settings and I was able to install.
  • rogertsai(AAEON)rogertsai(AAEON) New Member Posts: 139 ✭✭✭
    Hi all,
    if you still have problems to install ubuntu on UP, please refer to the following steps
    1. Download Ubuntu 16.04.3 iso
    2. Download Rufus
    3. Ceate USB installation media from Ubuntu 16.04.3.iso, Partition default for MBR parition sheme for BIOS or UEFI computes
    4. Change the boot setting for boot from USB flash drive
    5. Install Ubuntu, and reboot when complete installation or system asking for reboot
