Select Boot Device?
David
New Member Posts: 30 ✭
Hi there!
i just installed my own Linux with a custom kernel - sadly this kernel has a bug and gets a kernel Panic during boot.
My Problem: i cannot boot from stick or DVD anymore because the Up-Board simply boots my custom efi-entry all the time, even if i disable it in the bios.
Is there a way to force the up to boot from a specified device?
Thanks in advance!
Thanks in advance!
Hi David
If you press F7 during boot (when the BIOS splash screen appears), do you see a choice of boot options?
Regards,
-Dan -
yes, i have. This is really weird:
i only added one entry to uefi, but in bios i can see my named entry and "Android-IA". if i start with F7 i get the boot menu, but only Android-iA is visible, not my DVD, nor my usb-stick.
if i disable the eMMC in bios, all devices ready for boot are listed when booting with F7. So my Workaround will be: disabling eMMC, Clearing the NVRAM from the UEFI and then try it again.
Smells like a bug in the bios me thinks -
still no success. i bootet a live-dvd and cleared all efi-boot-entries.
no luck, the board will still boot the corrupted kernel as soon as i re-enable the emmc.
There is one bootmanager entry visible in the bios: "Android-TA". I cannot see, nor delete that via evivars and i cannot boot from an external media while the emmc is active. really weird. Someone has another suggestion? -
This might have something in common with another thread:
https://up-community.org/forum/public-othersw/262-problem-installing-windows10
Could you check if toggling the Boot > OS Image ID setting makes any difference?
Thanks for the report! -
just as a side note: it works now. i switched between many usb-sticks and one did allow me to boot while the emmc is active. the one i used yesterday still only works while the emmc is deactivated - but yesterday i could leave the emmc activated no matter what.
well, as long as it works now, i am fine
