BIOS settings for Futurelabs 7"W eDP screen
Gordon Paterson
Gordon Paterson New Member Posts: 6 ✭
I'm having an issue getting the up2 to display it's output on the screen. I have followed the instructions for the DIP switch on the interface board, 1 & 8 set to off 2 -7 set to on position.
In the BIOS (V2.1) I have changed the North bridge IGD Boot Type to eDP.
What am I missing?
Thanks.
Best Answer
  • Aling
    It sounds strange. Did you get your Futurelab display from UP shop after March 2017?
    Before March 2017, the display doesn't support eDP signal.
  • Gordon Paterson
    The interface board is the TFC_UP2EDP variant with the DIP switch for changing between eDP and MIPI. I also have an UP board and screen as well, so I have tried changing the screen and cables between the two. The UP board displays using the original interface board but using the UP2EDP variant doesn't display using either the UP or UP2.
  • ct_ipc
    ct_ipc New Member Posts: 3 ✭
    Did you have solution? I have similar issue
