My UP Core doesn't boot-ubilinux
New Up core board arrived this morning, battery and heatsink already attached,
1st thoughts are, Its very cute
I notice in the step by step guide sheet, that I have to check the sink and battery are all ok, check
Step 2
go to the the Up-community.org and get software......ah Huston ....problem...etc
Where are the OS's?
I had assumed there'd be something on the eMMC but applying power gives no response, no screen no LED's....
so...what's the procedure?
Step 2
Where are the OS's?
But it does seem this is DOA, nothing going to the screen at all, no indication of a boot.
My new UpCore board with my new Up supplied power system.... is showing no signs of life. I followed the steps provided even though I know what I'm doing with SBC's, (I have 30 or so) and it does not boot. I am hoping that its a DOA issue, because a lot of people are getting these boards delivered right now and if there is something causing them not to boot, or to appear not to boot, there may be a lot of confused people.
I'm also frankly a little surprised that no one from Up has actually offered a suggestion.. This is where hundreds of new owners are going to be looking in the next few days, you guys should be on top of questions like this,.
I now have it up and running and will start to fiddle about
well it works, but its painfully slow, seems to only have 1 core working, and it is currently lacking drivers for OpenGL/GLES
I have an Up^2 board which uses the same OS and despite it being a dual core celeron, its outperforms this UpCore board in every way....
so far very unimpressed, will wait to see if a new version of the OS cures the issue.
