Just Killed my new up board
Martin Hall
Martin Hall New Member Posts: 8 ✭
Yesterday received my new up board, set it up all working fine, then disaster.
I use it with a robohat that has a 11V supply (with the same plug), pluged the wrong plug into the up board.
Now the up board boots into linux as can be seen from the hdmi output.
But there is now no 5v to the USB so cant communicate with it.
should i be able to use it with a powered USB hub ?
is there any other way of powering it?
Martin
