Hi-Safe cant recognize Board ID
After starting Hi-Safe I get the following Error:"Can't recognize board ID:". This is on a freshly set up Board with nothing installed but UpBoard Drivers and Hi-Safe.
Please check the installed version , which may resolve your problem .
try with different versions. it will work .
i have faced same issue. -
What’s Hi-Safe version you use ? which websit do you download to get this ?
Did you install aaeonFramework driver on your UP ?
The Hi-safe only support for System Information, H/W Monitor and Dio features for UP board -
I installed the newest Version from http://www.aaeon.com/en/ac/aaeon-hi-safe.
aaeonFramework was installed before installing HiSafe -
I am using UP2 with Win10 Pro Intel Pentium and have the same problem as stated above ("can't recognize board id") using Hi-Safe Ver 1.2016.08.01. The message changes to "Can't initialize the Application FFFFF0FF" and afterwards followed by "This board is not supported. Please contact with service window" using Hi-Safe Ver 2.2016.07.01. aaeonFramework service driver date is 08/11/2017.
Running the demo SDK DIO gives "Can't read DIO 3/5/7/8 value: Hardware not ready. Please check BIOS settings".
Can anybody help with that issue? Seems like I don't have a working combination of Board/aaeonFramework/Hi-Safe...
O -
Short Update,
changed all the GPIO Settings in BIOS. Now the SDK DIO sample application is running without errors
Unfortunately, Hi-Save is still not running in both versions.
Any ideas what the reason could be? -
I'm getting a similar issue with my UP2. I had managed to get the sdk dio and my own code to work on my UP board but when I've moved over to the UP2 I get "Can't initialize the Application FFFFF0FF" then other messages saying it can't get / set the IO pins. I have changed the HAT settings in BIOS V3.3 so that all the SPI, I2C etc. are disabled and the GPIO are all input apart from the one pin that I am using as an output.
I have tried various versions of the Hi-safe framework, the one that I have working on the UP board is v2_20170314. I have downloaded 20170913 but there is only cpp examples and there only seems to be the x86 aaeonEAPI.dll where as the previous version had c# examples and both the x86 and x64 variants of the dll and I need the x64 variant.
I also tried using the aaeonEAPI.dll dated 11/08/2017 that comes with the c# dio example v20171031 but the dio and my own code abort without any warning as soon as they run.
Any ideas of what version of the Hi-safe framework I should be using to get my project working?
@rogertsai(AAEON) said:
please try to use the Hi-Safe v2 as below
Hi-Safe_v2_20171127
UP-Board aaeonFrameworkHello, the links have expired, can you please refresh them, or better still, please add these files to the downloads section.
Roland -
Hi-Safe_v2_20171127
RolandClick on the link below to download. There are three functions supported, System Information, H/W Monitor and DIO.
Hi-Safe_v2_20180522 -
@OH said:
Short Update,
Any ideas what the reason could be?Hi OH, My i know what are the changes you made in bios? I'm new using upboard and currently trying to find a way to use the GPIO,
Thanks in advance
