UP2 not powering on.
2»
  • Nicola Lunghi
    edited November 2017
    write an email to shop@up-board.org or better send a message to AlingWu on this forum.
    If you cannot contact them in this way please let me know I will try on my side (but its more complicated)
    Nicola Lunghi
  • Aling
    @Caldor, please drop me an email via info@up-board.org, and post the discussion thread. I will help you from there.
  • Kasper Olesen
    Kasper Olesen New Member Posts: 10 ✭
    Thank you, I have sent you a mail and linked this thread. If you meant I should make a new thread about it here, then I will do that.
  • Warren
    Warren New Member Posts: 2 ✭
    Was suffering the same problem with my Kickstarter UP2. Trimmed the thermal pad so that it only covered the main raised part of the CPU and not the other surface mount components, then reattached the heat sink without over-tightening and for the first time it booted into the BIOS. Have managed to happily install Ubuntu 16.04, all with my 5V/4A power supply for now.
  • Brian Robbins
    Brian Robbins New Member Posts: 4 ✭
    @Warren
    Thank you! Performing surgery on the cpu thermal pad was the only thing that got my UP2 board to work reliably, unlike the "official fix." Had just about written off the darn board!
  • JtagHJ
    JtagHJ New Member Posts: 6 ✭
    edited August 2018
    I am a kickstarter backer.
    I got the same issue.
    Then I try run win10 with Funmark's GPU stress test (16/9 11520x2160) and no ABS plastic case.
    1. remove heatsink and two thermal pad (N4200 and another purple thermal pad)
    2. attached heatsink with N4200's thermal pad only (no screw, no bronze color stand-off)
    3. base on 2. Trimmed the thermal pad so that it only covered the main raised part of the CPU and not the other surface mount components.
    4. base on 3. Use fan let heatsink temperate down.
    item 1 : I am not share. It seems work fine but overheat.
    item 2 : win10 still unstable, random reboot system
    item 3 : win10 still unstable, random reboot system
    item 4 : win10 still unstable, random reboot system
    PS. The power adapter spec is 5V/4000mA when I received up squared II.
    I am very upset and no idea what to do next ? :(
  • JtagHJ
    Add some photo.
  • Brian Robbins
    @JtagHJ
    Larger thermal pad maybe not thick enough? And you put the other smaller thermal pad back, too?
  • JtagHJ
    edited August 2018
    @Brian Robbins said:
    @JtagHJ
    @Brian Robbins
    -> The pink color thermal pad thickness is close to 0.8t/mm.
    -> I tried 2.0t/mm(black) and 0.8t/mm(pink) with heaksink , screw, and bronze color stand-off . (see IMG_8663.jpg, thermal pad)
    -> The 2.0t/mm seems too thick. The system very unstable after boot.
    -> no
    Thank you!
  • JtagHJ
    edited August 2018
    update something.
    I use ADIA64 to measure cpu package power.
    The cpu package power at window 10 desktop about 1w~5w when boot finish.
    Then open Furmark's GPU stress test (16/9 11520x2160) .
    Sometimes system crash directly.
    Sometimes GPU stress test work.
    The cpu package power about 13w~15w when GPU stress test work.
    The Power Supply (5A/4A) pumping current output from 5w to 15w immediately.
    I am not sure if there is a problem.
    So.
    I use a 5V/6A 30W Power Supply. (see attach file)
    then
    1. remove all thermal pad
    2. put N4200's thermal pad only (Trimmed the thermal pad so that it only covered the main raised part of the CPU and not the other surface mount components.)
    3. tightening heatsink with bronze color stand-off (take care BIOS can boot)
    4. tightening ABS case screw (take care BIOS can boot)
    The CPU0~3 temperate about to 103'C when games, facebook, youtube, furmark (gpu test, cpu burner test), AIDA64 execute same time.
    I am not sure but it's seem work fine.
    Any idea ?
    Here is the Power Supply Spec:
    VENDOR : DELTA ELECTRONICS
    MODEL : EADP-30NB D
    INPUT : 100-240V~0.8 (800mA) 50~60Hz
    OUTPUT : 5V/6A
  • JtagHJ
    add photo for test case.
