UP Squared stopped working
my Kickstarter-UP Squared (Pentium Ultra-Package) suddenly stops working today. When switched on, the blue LED lights up, but apart from that there is no sign of life. No signal is output via HDMI, the LEDs on the network port do not light up. Since I got the UP Board I have installed Debian 17.10 on eMMC and played around a few times over SSH. No external devices plugged in, no GPIOs used.
I have already searched the forum, but can not find a suitable answer. What can I do?
Best regards,
Holger Ebert
  • eduncan911
    To help preempt a reply from Aaeon, what exact power supply were you using?
  • Holger Ebert
    Holger Ebert New Member Posts: 3
    The original plug-in power supply from the Kickstarter package (5V / 4A)
  • rogertsai(AAEON)
    Did you try to use display port (DP)? if it's still not working, try checking your keyboard Num lock LED is working or not. If the lock LED not working, it means the bios cannot boot from the drive or other HW issue...
  • Holger Ebert
    Sorry, i have no display port-cable and/or monitor to use with. Have connected an old wired USB-keyboard, non of the LED on the keyboard worked.
  • rogertsai(AAEON)
    try to remove the cmos battery to reset the bios, if it's still not working..
    please contact your original retailer or nearest AAEON dealer for warranty assistance
