mPCIe 3G module kit (RE-UP3GKITSIM01) The antenna connects to the Main connector
Fabio
Fabio New Member Posts: 22 ✭
Hello
On the electronic board mPCIe 3G module kit (RE-UP3GKITSIM01 there are 3 conector for antennas . Is the GSM / UMTS antenna that is supplied connected to the MAIN connector?The other two are for what they serve? Thanks
  • Aling
    edited October 2017
    Please connect it to " main" connector.
    In general, if there are 3 connectors in a row, RF connectors oriented on the top of the PCB:
    LEFT antenna is the main antenna for 3G
    MIDDLE antenna is for GNSS
    RIGHT antenna is for Antenna Diversity
  • Fabio
    ok thanks @AlingWu
