Up only boots into BIOS after BIOS update
I wanted to install ubilinux 4.0 so I updated the BIOS to the latest version as advised.
UPC1BM0X_EFI
Once updated ever time I boot the UP automatically enters BIOS setup.
If I press F7 I can see all my boot options but when I select one it just enters BIOS setup.
I tried loading default BIOS settings but it made no difference.
Dear duddled
have you followed the instruction at https://up-community.org/wiki/Ubilinux ?
Best Regards
Nicola Lunghi -
Hi duddled,
Can you try the steps provided by roarcor on this topic?
https://up-community.org/forum/public-ubilinux/968-start-in-shell-mode-because-ubilinux-not-found-anymore-after-unplug-power-supply#5938 -
I have tried the Ubilinux innstall image, Live Boot Ubuntu and bootable EFi shell. All enter the BIOS setup when selected.
I have 6 UP boards and this only happens on the one I tried to update the BIOS of. -
Please disconnect the RTC battery for a couple of minutes, then reconnect the battery and boot up the system.
Does the UP BIOS logo show up after boot? If so please press F7 and let me know what are the available options. -
When I press F7 without a bootable USB the options are
[ul]
[li]Enter Setup[/li]
[/ul]
If I press F7 with my Ubuntu USB is shows
[ul]
[li]UEFI: Corsair Voyger Sl.....[/li]
[/ul]
But irrespective of which option I select it entered the Aptio Setup Utility. -
I have encountered this issue with my upboard^2 and bios UPA1AM18.
I am going to RMA mine.
Same problem, but I am seeing this issue out of box. The board never booted to an OS. I was able to boot from an Ubuntu 16.04 USB stick and install the OS, but the board never boots into the OS. It keeps booting into BIOS setup.
BIOS Version: UP-APL01 R2.1 (9/1/2017)
Does the eMMC get detected at all in the BIOS? We had a couple of Ups that suddenly had the eMMC disappear completely. If the board keeps booting to BIOS it could mean there's nothing bootable discovered, which hints at some problem with the eMMC.
Delicode Ltd - https://www.delicode.com/
Please make sure you are installing the system with boot/grub in UEFI mode and not legacy.
During installation you can select manually to partition your disk, then delete all partitions and create new ones (1 EFI partition 512MB, a root partition with the remaining space).
