[SOLVED] Problems installing mariadb
Bartek
Bartek New Member Posts: 16
edited October 2017 in UP Board Linux
I am trying to install mariadb server on latest ubilinux. Installation fails with error:
Setting up mariadb-server-10.1 (10.1.26-0+deb9u1) ...
logger: socket /dev/log: Connection refused
dpkg: error processing package mariadb-server-10.1 (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of default-mysql-server:
 default-mysql-server depends on mariadb-server-10.1; however:
  Package mariadb-server-10.1 is not configured yet.
dpkg: error processing package default-mysql-server (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of mysql-server:
 mysql-server depends on default-mysql-server; however:
  Package default-mysql-server is not configured yet.
dpkg: error processing package mysql-server (--configure):
dpkg: dependency problems prevent configuration of mariadb-server:
 mariadb-server depends on mariadb-server-10.1 (>= 10.1.26-0+deb9u1); however:
dpkg: error processing package mariadb-server (--configure):
Errors were encountered while processing:
 mariadb-server-10.1
 mysql-server
 mariadb-server
E: Sub-process /usr/bin/dpkg returned an error code (1)
I have tried full restart and removing all packages with --purge, then autoremove and autoclean. Nothing helps.I have searched in google, but still no luck. I am looking for solution for three days.
My system is running UP2 128G/8G MP, uname -a shows
Linux UP 4.9.45-ubilinux+ #2 SMP Fri Sep 8 10:51:36 IST 2017 x86_64 GNU/Linux
Any help would be greatly appreciated
  • WereCatf
    I just tested on my box and mariadb-server installed without any issue at all. Have you updated all installed software? Or have you messed with systemd-configuration or something?
  • Bartek
    edited October 2017
    I have reintalled ubilinux, and now it works. Thanks fot thr tip
