[SOLVED] Problems installing mariadb
Bartek
New Member Posts: 16 ✭
I am trying to install mariadb server on latest ubilinux. Installation fails with error:
I have tried full restart and removing all packages with --purge, then autoremove and autoclean. Nothing helps.I have searched in google, but still no luck. I am looking for solution for three days.
My system is running UP2 128G/8G MP, uname -a shows
Regards
Setting up mariadb-server-10.1 (10.1.26-0+deb9u1) ... logger: socket /dev/log: Connection refused logger: socket /dev/log: Connection refused dpkg: error processing package mariadb-server-10.1 (--configure): subprocess installed post-installation script returned error exit status 1 dpkg: dependency problems prevent configuration of default-mysql-server: default-mysql-server depends on mariadb-server-10.1; however: Package mariadb-server-10.1 is not configured yet. dpkg: error processing package default-mysql-server (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of mysql-server: mysql-server depends on default-mysql-server; however: Package default-mysql-server is not configured yet. dpkg: error processing package mysql-server (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of mariadb-server: mariadb-server depends on mariadb-server-10.1 (>= 10.1.26-0+deb9u1); however: Package mariadb-server-10.1 is not configured yet. dpkg: error processing package mariadb-server (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: mariadb-server-10.1 default-mysql-server mysql-server mariadb-server E: Sub-process /usr/bin/dpkg returned an error code (1)
Linux UP 4.9.45-ubilinux+ #2 SMP Fri Sep 8 10:51:36 IST 2017 x86_64 GNU/LinuxAny help would be greatly appreciated
Regards
I just tested on my box and mariadb-server installed without any issue at all. Have you updated all installed software? Or have you messed with systemd-configuration or something?
I have reintalled ubilinux, and now it works. Thanks fot thr tip
