Got my UP Squared... but how to attach the antenna?
Kasper Olesen
New Member Posts: 10 ✭
in Peripherals
I have installed the board into the casing and I am about to install a OS on it. I also installed the bluetooth / WiFi chip in that M2 port, but I could not figure out how to attach the antenna? I tried finding a guide but I could only find stuff about cases with antennas on the outside.
Here is the antenna
And this is the chip for wireless connections:
I am guessing others have figured this out? I suspect one of those two holes on the chip? There is some tape or something on the antenna chip board, I have not tried removing it yet because I wanted to know where to put it first... and how.
Here is the antenna
There are those two, tiny connectors marked with 1 and 2, those are where the antenna goes to. Just place the tiny plug on top of the one marked as 1 and try to push it straight down -- take a little care not to push it at an angle. It's easier if you've got some object handy with a flat surface that you can use to push it down with; place the plug on top of the connector, then the object's flat surface on top of the plug and gently push down.
That is what I tried at first, just did not want to risk damaging it. Thanks for the tip
- 3.5K UP Products
- 23 UP 7000
- 15 UP Squared Pro 7000
- 24 UP Xtreme i11
- 141 UP Xtreme
- 223 UP Core
