I installed ubuntu-16.04.2-desktop-amd64.iso Still no serial port working.
Raymond Day
New Member Posts: 67 ✭
I downloaded ubuntu-16.04.2-desktop-amd64.iso right from this UP web place and installed it.
Wanted to get the serial port working and did just what it says to do on the /etc/default/grub.d file.
When I got to update-grub it comes back with:
Any way to fix this?
On my old install of ubuntu server I got the serial to work at lest to send data but I could not type on it.
-Raymond Day
root@Ubunt-UP-APL01:~# update-grub "nvalid output terminal "gfxterm serial
-Raymond Day
[/url]Looked on Google for help with this.
It worked so when I do the update-grub I get no error.
So I rebooted and all the serial port shows now is this:error: serial port `com0' isn't found. error: terminal `serial' isn't found. error: terminal `serial' isn't found. error: no video mode activated.
I guess it's not com0 but I thought it would be How they talked about it here..
Checked what com ports it uses by doing a apt install setserial then this:[code]root@Ubunt-UP-APL01:~# setserial -g /dev/ttyS[0123456789] /dev/ttyS0, UART: unknown, Port: 0x03f8, IRQ: 4 /dev/ttyS1, UART: unknown, Port: 0x02f8, IRQ: 3 /dev/ttyS2, UART: unknown, Port: 0x03e8, IRQ: 4 /dev/ttyS3, UART: unknown, Port: 0x02e8, IRQ: 3 /dev/ttyS4, UART: 16550A, Port: 0x0000, IRQ: 4 /dev/ttyS5, UART: 16550A, Port: 0x0000, IRQ: 5 /dev/ttyS6, UART: unknown, Port: 0x0000, IRQ: 0 /dev/ttyS7, UART: unknown, Port: 0x0000, IRQ: 0 /dev/ttyS8, UART: unknown, Port: 0x0000, IRQ: 0 /dev/ttyS9, UART: unknown, Port: 0x0000, IRQ: 0 root@Ubunt-UP-APL01:~#
[/code]
Edit the /etc/default/grub.d/serial.cfg file to put com 4 in it not 0.
Did update-grub again and rebooted.
Now says:
error: serial port `com4' isn't found.
So maybe it's 5 but at lest I got some other text back on the serial port this time.[ 29.215540] mmc1: Timeout waiting for hardware interrupt. [ 29.221581] sdhci: =========== REGISTER DUMP (mmc1)=========== [ 29.228097] sdhci: Sys addr: 0x00000020 | Version: 0x00001002 [ 29.234611] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000020 [ 29.241117] sdhci: Argument: 0x06140870 | Trn mode: 0x0000003b [ 29.247633] sdhci: Present: 0x1fff0001 | Host ctl: 0x0000003d [ 29.254138] sdhci: Power: 0x0000000b | Blk gap: 0x00000080 [ 29.260653] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 29.267169] sdhci: Timeout: 0x00000004 | Int stat: 0x00000000 [ 29.273676] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02ff000b [ 29.280193] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000 [ 29.286710] sdhci: Caps: 0x546ec881 | Caps_1: 0x80000807 [ 29.293227] sdhci: Cmd: 0x0000123a | Max curr: 0x00000000 [ 29.299733] sdhci: Host ctl2: 0x0000008d [ 29.304113] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000026db07200 [ 29.311403] sdhci: =========================================== [ 29.322195] mmcblk1: error -110 transferring data, sector 101976176, nr 32, cmd response 0x0, card status 0x0
But I still can not type on it.
-Raymond Day -
That last part on the last post of "mmc1: Timeout waiting for hardware interrupt." keeps repeating seems like all most every time I do a command on the system.
I did not get that when I had just the server installed. Now have the Desktop installed of Ubuntu.
-Raymond Day -
in Ubuntu the serial number could be different than tty0.
Do this:
[ol]
[li]executesudo find /sys/devices/pci0000\:00 -name *tty* /sys/devices/pci0000:00/0000:00:18.0/dw-apb-uart.8/tty /sys/devices/pci0000:00/0000:00:18.0/dw-apb-uart.8/tty/ttyS4 /sys/devices/pci0000:00/0000:00:18.1/dw-apb-uart.9/tty /sys/devices/pci0000:00/0000:00:18.1/dw-apb-uart.9/tty/ttyS5
and take note of the number of the terminal where the first uart is (in my case ttyS4)
[/li]
[li]modify as the guide says the grub configuration like thissudoedit /etc/default/grub.d/serial.cfg
GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX console=tty0 console=ttyS4,115200n8"
GRUB_TERMINAL="console serial"
GRUB_SERIAL_COMMAND="serial --unit=0 --speed=115200"
[/li]
[li]sudo update-grub
[/li]
[li]start the serial terminal with:sudo systemctl start getty@ttyS4
[/li]
[li]enable permanently the serial terminal with:sudo systemctl enable getty@ttyS4
[/li]
[/ol] -
Thanks I did what you said and the 1st time seems like the commands worked and I rebooted. But no serial port still.
So log on again and copied and paste your /etc/default/grub.d/serial.cfg I think I had it the same any way but wanted to make sure.
But then I got a Not foundrub-mkconfig like this:login as: root root@192.168.86.111's password: Welcome to Ubuntu 16.04.3 LTS (GNU/Linux 4.10.0-33-generic x86_64) * Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/advantage 0 packages can be updated. 0 updates are security updates. Last login: Thu Sep 14 06:25:30 2017 from 192.168.86.59 root@Ubunt-UP-APL01:~# find /sys/devices/pci0000\:00 -name *tty* /sys/devices/pci0000:00/0000:00:18.0/dw-apb-uart.8/tty /sys/devices/pci0000:00/0000:00:18.0/dw-apb-uart.8/tty/ttyS4 /sys/devices/pci0000:00/0000:00:18.1/dw-apb-uart.9/tty /sys/devices/pci0000:00/0000:00:18.1/dw-apb-uart.9/tty/ttyS5 root@Ubunt-UP-APL01:~# nano /etc/default/grub.d/serial.cfg root@Ubunt-UP-APL01:~# update-grub : not foundrub-mkconfig: 4: /etc/default/grub.d/serial.cfg: root@Ubunt-UP-APL01:~#
double check all the parenthesis on the file /etc/default/grub.d/serial.cfg sometimes the wiki changes the parenthesis type
if it doesn't work delete the file /etc/default/grub.d/serial.cfg and modify directly the /etc/default/grub file
1. change the lineGRUB_CMDLINE_LINUX=""
withGRUB_CMDLINE_LINUX="console=tty0 console=ttyS4,115200n8"
2. change the line#GRUB_TERMINAL=console
withGRUB_TERMINAL="console serial"
3. add after that lineGRUB_SERIAL_COMMAND="serial --unit=0 --speed=115200"
4. sudo update-grub
it works for me I've just tried it
Also double check if your serial cable is working
In theory after giving the command:sudo systemctl start getty@ttyS4
you should have a shell after boot in any case
(the grub lines are only to control grub and to see the kernel init message during boot)
If you cannot see a terminal then maybe you have a problem in your serial connection. -
That worked. I did delete it and made a new one.
Then rebooted but still don't get any thing over the serial port. I think I did see it before but just could not send any thing. Now can't even see it.
The end of a "dmesg" is about all in red. It looks like this:[ 38.628764] mmc0: Timeout waiting for hardware interrupt. [ 38.634805] sdhci: =========== REGISTER DUMP (mmc0)=========== [ 38.641319] sdhci: Sys addr: 0x00000008 | Version: 0x00001002 [ 38.647833] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000008 [ 38.654347] sdhci: Argument: 0x05d109a8 | Trn mode: 0x0000003b [ 38.660861] sdhci: Present: 0x1fff0001 | Host ctl: 0x0000003d [ 38.667375] sdhci: Power: 0x0000000b | Blk gap: 0x00000080 [ 38.673884] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 38.680400] sdhci: Timeout: 0x00000004 | Int stat: 0x00000000 [ 38.686914] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02ff000b [ 38.693427] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000 [ 38.699941] sdhci: Caps: 0x546ec881 | Caps_1: 0x80000807 [ 38.706452] sdhci: Cmd: 0x0000123a | Max curr: 0x00000000 [ 38.712963] sdhci: Host ctl2: 0x0000008d [ 38.717341] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000026db69200 [ 38.724630] sdhci: =========================================== [ 38.735394] mmcblk0: error -110 sending stop command, original cmd response 0x0, card status 0x400900 [ 38.735397] mmcblk0: error -110 transferring data, sector 97585576, nr 8, cmd response 0x0, card status 0x0 root@Ubunt-UP-APL01:~#
Not sure if that has any thing to do with the serial.
Thanks for helping.
-Raymond Day -
That error message has nothing to do with the serial
the uart is ttyS4
please check to do not have any other file in /etc/default/grub.d
if you have it please remove it and run update-grub again
as I was saying if you cannot see a serial terminal after boot and the service is enabled you probably have problem with you adapter/cable/etcetc
please check that your adapter is 3.3v and the wiring -
It worked. I switched the send and receive wires. Can't remember if I switch them before.
Here is what comes back it looks like no kernel booting code or just very little.Version 2.18.1263. Copyright (C) 2017 American Megatrends, Inc. Press <DEL> or <ESC> to enter setup. error: serial port `com0' isn't found. error: terminal `serial' isn't found. error: terminal `serial' isn't found. error: no video mode activated. error: no suitable video mode found. Booting in blind mode Ubuntu 16.04.3 LTS Ubunt-UP-APL01 ttyS4 Ubunt-UP-APL01 login: root Password: Last login: Thu Sep 14 07:19:02 EDT 2017 from 192.168.86.59 on pts/8 Welcome to Ubuntu 16.04.3 LTS (GNU/Linux 4.10.0-33-generic x86_64) * Documentation: https://help.ubuntu.com * Management: https://landscape.canonical.com * Support: https://ubuntu.com/advantage 0 packages can be updated. 0 updates are security updates. [ 39.865830] mmc0: Timeout waiting for hardware interrupt. [ 39.871865] sdhci: =========== REGISTER DUMP (mmc0)=========== [ 39.878373] sdhci: Sys addr: 0x00000010 | Version: 0x00001002 [ 39.884885] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000010 [ 39.891389] sdhci: Argument: 0x0659df20 | Trn mode: 0x0000003b [ 39.897902] sdhci: Present: 0x1fff0206 | Host ctl: 0x0000003d [ 39.904436] sdhci: Power: 0x0000000b | Blk gap: 0x00000080 [ 39.910948] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007 [ 39.917451] sdhci: Timeout: 0x00000004 | Int stat: 0x00000000 [ 39.923964] sdhci: Int enab: 0x02ff000b | Sig enab: 0x02ff000b [ 39.930466] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000 [ 39.936978] sdhci: Caps: 0x546ec881 | Caps_1: 0x80000807 [ 39.943492] sdhci: Cmd: 0x0000123a | Max curr: 0x00000000 [ 39.950006] sdhci: Host ctl2: 0x0000008d [ 39.954383] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000026d9c7200 [ 39.961672] sdhci: =========================================== [ 39.972344] mmcblk0: response CRC error sending r/w cmd command, card status 0x400900 root@Ubunt-UP-APL01:~#
Wow after all this time got it working.
Thank you.
-Raymond Day -
glad it worked (usually is the simplest thing that goes bad)
you still have some configuration problem (and the emmc error doesn't look good)
I suggest you to do a clean ubuntu install and then reenable the serial terminal
Also why don't you try our new ubilinx4? -
What is ubilinx4 ? I guess I have to reload it to get rid of the errors. Were is a link to the best ISO to reload it?
-Raymond Day -
error: serial port 'com0' isn't found.
error: terminal 'serial' isn't found.
error: no video mode activated.These errors are usually caused by the presence of GRUB_HIDDEN_TIMEOUT=0 in /etc/default/grub
Even though the default value is =0 this seems to cause the errors.The solution is to:
Edit: sudo nano /etc/default/grub
Deactivate the following line by commenting it out or deleting it:
#GRUB_HIDDEN_TIMEOUT=0Refer: https://askubuntu.com/questions/475993/grub-update-warning-in-ubuntu-14-04
Refer: https://bugs.launchpad.net/ubuntu/+source/grub2/+bug/699802
