Up board reliability (Ethernet/video problems)
Simon Jensen-Fellows
New Member Posts: 1 ✭
Just got my Upboard as part of the Intel Robotics Dev kit.
The Ethernet will not work at 100M speeds, only 1G.
The board will reboot correctly maybe 1 in 4 times; it looks like it is a video problem as I can usually ssh in.
How do I know if this is a bad board? Any pointers on troubleshooting it?
Hi Sjf, Could you give me the board part number, refer to the link below
part number
To Ethernet, the Ethernet chip's support for 10/100/1000Base x1 as below picture . can you briefly describe the error status of port, and how to reproduce
To reboot / Video issue, I’m not sure about this, but you can check out all of your devices and view their relevant drivers by using the device manager or by Terminal.
Maybe you can try this way below to check your device is work
>> Checking the power source, DC in 5v / 1.5A above
>> UP board power activity led is work
>> Install os and drivers
>> Reboot, and make sure your device is discoverable, and is working correctly.
