up broad usb 3.0 OTG to PCIE adapter problem
henry851018
New Member Posts: 3 ✭
I have a USB 3.0 to PCIE adapter it can use on eGPU for windows?
您好 我有一個USB轉PCIEX16的適配器 請問我該如何設置才能讓他在windows中抓到外掛顯卡並且使用它增加效能
Hi I have a USB to PCIEX16 adapter how to set up in order to let him catch the EGPU in windows and use it to increase performance
In the UP board spec, that baord only support USB2.0...
It is not a USB3.0 - device! The USB3-cable is only used for signal-transfer between the big PCB and the small PCB, neither of which are USB-devices -- whoever designed that board just didn't want to make a custom cable and chose a USB-cable for simplicity. All the magic happens in the small PCB, which is a mPCI-E - device, but there is no mPCI-E slot on the UP1 and so you can't use it.
One could use that on the UP2 as there is one available mPCI-E slot on it, but you'd still need to source the +12V and +5V from somewhere to actually power the external GPU up -- the UP2 doesn't have any +12V rails on it and it wouldn't be able to supply enough power to an external GPU anyways.
