up broad usb 3.0 OTG to PCIE adapter problem
henry851018
henry851018 New Member Posts: 3 ✭
I have a USB 3.0 to PCIE adapter it can use on eGPU for windows?
您好 我有一個USB轉PCIEX16的適配器 請問我該如何設置才能讓他在windows中抓到外掛顯卡並且使用它增​加效能
Hi I have a USB to PCIEX16 adapter how to set up in order to let him catch the EGPU in windows and use it to increase performance
  • rogertsai(AAEON)
    In the UP board spec, that baord only support USB2.0...
  • WereCatf
    It is not a USB3.0 - device! The USB3-cable is only used for signal-transfer between the big PCB and the small PCB, neither of which are USB-devices -- whoever designed that board just didn't want to make a custom cable and chose a USB-cable for simplicity. All the magic happens in the small PCB, which is a mPCI-E - device, but there is no mPCI-E slot on the UP1 and so you can't use it.
    One could use that on the UP2 as there is one available mPCI-E slot on it, but you'd still need to source the +12V and +5V from somewhere to actually power the external GPU up -- the UP2 doesn't have any +12V rails on it and it wouldn't be able to supply enough power to an external GPU anyways.
