GPIO drivers for IoT
wim
wim New Member Posts: 2 ✭
I want to create an UWP app using GPIO in visual studio 2017,to communicate with parallel port (printer port) of our embedded board. As start I use the "helloBlinky" example. But this app can not find the GPIO controller. I have the UP Drivers installed. Step 1-3 OK, step 4 was not succesfully. Step 1 seems to contain the GPIO driver because there is a GPIO folder in the driver path. I have installed Win 10 IoT enterprise on my up board. Have anyone experience with this?. Where can I found more info? please help
  • rogertsai(AAEON)
    You can use the GPIO SDK to link your embedded board
    please click the link below to download a SDK file
    GPIO SDK
    please note: the SDK file is not UWP app
  • wim
    Yes I had already found this example code, but my problem is to detect (rising/falling) edges of an input line. The frequency of my data is approx. 100khz-1Mhz, so polling is not an option. Is there an example of how to do this?
  • rogertsai(AAEON)
    unfortunately the SDK doesn’t support that kind of function...
  • RolandP
    RolandP New Member Posts: 6 ✭
    GPIO SDK
    Hi Roger,
    The aaeonFrameworkSetup zip file in the Hi-Safe driver is detected as containing 2 viruses: Trojan:Win32/Vagger!rfn and Trojan:Win32/Bitrep.A. Can you please host the clean files on the UP Squared downloads page?
    Roland
  • rogertsai(AAEON)
    edited May 2018
    @RolandP said:
    Hi Roger,
    Roland
    I share file on my onedrive. It's UP Squared SDK reuploaded.
    UP-APL01_20180525.zip
  •  Connor Early
    Connor Early New Member Posts: 20 ✭✭
    What if we want to use GPIOs with a UWP app?
