I have not been able to get the display port to work.
Ryan
Ryan New Member Posts: 3 ✭
Hey all,
I can't seem to get the display port to work. Used the windows driver to updated, but it did nothing. I booted into Ubuntu and that didn't find the port either. Any suggestions?
  • Ryan
    Bump !?
  • Aling
    If you are using Windows, can you make sure the graphics driver is 21.20.16.4550 version. Check the download area, then you will get it.
  • Ryan
    Thanks for the reply. I've installed the driver, uninstalled and reinstalled. No luck. I also flashed the bios thinking that might help. I also booted into linux and no display is detected.
