Windows USB3 driver compatibility ?
Martin Mayr
New Member Posts: 54 ✭
Hello
The USB3 port on the UP board is it compatible with any USB3 device under Windows 10 x64 ?
Known limitations ?
Known problems ?
Best regards
Known limitations ?
Known problems ?
Best regards
Most of the problem for USB3.0 compatibility is the cable.
Make sure you get a good cable , or buy it from UP shop. Many problems were solved after they replace the cable. I hope this would help. :-)
