Windows USB3 driver compatibility ?
Hello
The USB3 port on the UP board is it compatible with any USB3 device under Windows 10 x64 ?
Known limitations ?
Known problems ?
Best regards
Known limitations ?
Known problems ?
Best regards
Make sure you get a good cable , or buy it from UP shop. Many problems were solved after they replace the cable. I hope this would help. :-)
