Dan O'DonovanAdministrator, Moderator, EmutexPosts: 241admin
No, UP cannot be powered directly by PoE. You'd need to use an adapter to split out the PoE supply on the Ethernet cable to a 5V supply on a barrel jack that you can plug into the UP board.
Have you tested any other PoE splitters?
Hi All,
PoE HAT is available now for both UP and UP2 board
Where can you buy this from?
I'd like to know, too, where to buy this!
I'm interested as well.
https://up-shop.org/home/245-poe-expansion-module.html?search_query=poe&results=1
