FreeBSD 11 / pfSense 2.4.x
Hrvoje
New Member Posts: 2 ✭
Since FreeBSD 11 will (should) work i assume that pfSense 2.4.x (which will be based on FreeBSD 11) will work also.
Did anyone try an 2.4.0 Alpha release:
https://snapshots.pfsense.org/
This question will be more interesting when UP 2 (UP Squared) board came to life, since we will then have a great platform for Firewall/Router/IDS/IPS/Proxy/Load Balancer/etc (using pfSense primary) which can be in low price margin for SOHO.
I got in the boot menu of pfsense. But during the boot i got errors. I expect this to work when gets out of beta.
I got into the boot menu of pfsense. The install was not successful. But this is still in ear lie phase of development. So i look forward to release of pfsense 2.4 and expect it to work in the near future.
I got to the boot menu on my UP2 but things went weird, I've just sent my board back as I think it was faulty though
But what about running an ESXi hypervisor on the board, then creating a "regular non-uefi" machine for pfSense running over the top with both the NICs as passthrough hardware, I don't see why this wouldn't work, pfSense is a pretty light footprint. Then run Photon alongside and you've got a pretty sweet router/firewall/docker machine
Even with the 2Gb RAM units it might be possible with this hack - https://community.spiceworks.com/topic/411970-installing-esxi-5-5-with-4gb-ram-memory_size-error
I'm going to test this when my unit comes back. -
The purpose for which I would the Up2 board was to run it as a headless PFSense Firewall.
I have this running using the 2.4.0-BETA (amd64) image.
Unplugging the UTP cables makes the Up2 crash, which I have read might be due to some Reaal chipset/FreeBSD issues. But since I'm not connecting any host devices to it just an NTE and a LAN switch, this is not an issue for me.
Boot-up time is long due to PCI bus error messages, also a known FreeBSD problem, but it eventually does boot.
Otherwise it doesn't seem not break a sweat running a VPN at 75Mb up/down and Squid, Snort etc.., so I'm happy. -
I assume you were not able to get it to recognize the eMMC? I keep getting a PCI scan timeout at noted elsewhere. Sure, I can ignore it but then it cannot find the eMMC.
Did you have different success?
