Hello!
Dominic
Dominic New Member Posts: 3 ✭
Hi everybody, purchased an UP 2/16 last week.
Installed ubuntu 16.04 with up kernel, testing my apps.
So far very pleased with Up's performance and build quality, but struggling with i/o.
    Hi Domius,
    We will release an updated ubilinux (based on Debian Stretch) next week which includes the I/O support.
    Later in June also you will be able to download a custom Kernel for Ubuntu which will enable the I/O on UP Squared.
  • Dominic
    edited June 2017
    Hi Dcleri!
    Thank you for prompt reply. Sorry for my ambiguity, my UP is not squared, but 2GB ram / 16GB mmc version.
    My problem are floating inputs. This next message from system log is generated when my app sets pull-up / down mode: "gpio27: mode: Failed to open 'drive' for writing: No such file or directory"
    Tried with pull-up resistors, no success. Problem gets worse once the UART port is activated.
    App is written in Java, using mraa library.
    Are internal pull-up/down resistors going to be supported in new release?
    BR
  • Dan O'Donovan
    Hi domius
    Unfortunately the hardware on UP does not provide configurable pull-up/down resistors for the 40-pin header. So you would need to use external pull-up resistors instead.
    -Dan
  • Dominic
    Hi Dan
    What is recommended resistor value for the pullup?
    Tried many:1.8, 2.2, 4.7, 10k, no success, still floating.
  • Dan O'Donovan
    I'd say it would depend on the rest of the circuit that you have connected. But those resistor values should generally be fine.
    Before I could help you further, I think I would need more insight on which pins you're using, how exactly you are setting up and using those pins, and how the issue is manifesting.
