BOINC and Wifi don't work together? (not solved but workarond)-UP Squared
LennStar
Posts: 23 ✭
tl; dr: complete report:
complete report
workaround: use prior Manger version 7.4.42 instead of 7.6.33
I want to run the BOINC software ( http://boinc.berkeley.edu/ ).
But it seems that BOINC cannot live with the Up² Wifi (cable not tested so far, but I can't use cable at the position)
As long as there is no internet connection, everything is fine.
But the moment a BOINC projects seeks to connect to the internet, the Manager loses contact to the client.
And if the contact is stable for half a minute, browser etc. say there is no internet connection.
Wifi: The one from the up shop
OS: Win 10 home and Win 10 pro same thing. I tried Linux Mint on USB stick but there Wifi didn't even connect to the router. I could see the Wifis and put in the Wifi key but thats all. I am a Linux noob, so idk.
Anyone else using BOINC??
complete report
Additional testing:
Problem persists on different Wifi and cable.
Older BOINC version works though.
Found only very few other instances of this problem (German): http://www.planet3dnow.de/vbulletin/threads/425402-Boinc-Probleme
Boinc Client in den letzten 3 Minuten 3 mal unerwartet beendet - BOINC client was stopped unexpectedly 3 times in the last 3 minutes
same as for me. -
complete report
