UP Core-Heatsink or fan or less
Markus
Markus Posts: 4
edited December 2017 in Peripherals
I have ordered one Up core on KickStarter.
Can I use this without a fan or heatsink? I think about a full power application with openCV oder openAI for example?
Its possible to use the http://up-shop.org/up-peripherals/111-active-cooler-fan-for-the-up-board.html on the up-core?
  • Aling
    Aling Posts: 561 admin
    We will still suggest you use a heatsink, although we made it work without heatsink as well. It really depends on what you run on UP Core.
    The active cooler for UP will work on UP Core, but we will make a different version to accommodate the difference heights in some components.
  • Markus
    Markus Posts: 4
    Thanks for your response.
    Will the new active cooler released in august 2017?
  • Aling
    I think it would be possible. We will try to work it out.
