Is 5A enough for the UP squared N4200 version
Mialaret
New Member Posts: 33 ✭
I have a hard time finding a 5V 6A power supply.
Would 5A be enough for the Up Squared with Pentium N4200 version ?
You can try, but we only tested the one available on the UP Shop: http://up-shop.org/up-peripherals/126-up-squared-power-supply-5v6a.html
It should be more than enough, unless you decide to use all the pheripherals, internal and external, at the same time. -
As long as you don't push CPU and GPU to limits at the same time and add lots of periphery it should work.
I can only say at my install tries the highest I had seen was 16W on the meter. 5A is 25W. That leaves 9W for GPU and periphery. -
I may order it from the store, however Ships in 7 days is a turnoff as I just received the up squared ;-)
