librealsense installation
Thomas
New Member Posts: 18 ✭
I was wondering if anyone has had success installing the latest librealsense library from https://github.com/IntelRealSense/librealsense to their up board. I am using the original up-board with 32gb memory and 4 gb ram.
During install I encounter the error
[ 61%] Building CXX object examples/CMakeFiles/cpp-config-ui.dir/cpp-config-ui.cpp.o
/home/tck/librealsense/examples/cpp-config-ui.cpp: In function ‘void show_message(GLFWwindow*, const string&, const string&)’:
/home/tck/librealsense/examples/cpp-config-ui.cpp:272:20: error: ‘GLFW_FLOATING’ was not declared in this scope
glfwWindowHint(GLFW_FLOATING, GL_TRUE);
examples/CMakeFiles/cpp-config-ui.dir/build.make:54: recipe for target 'examples/CMakeFiles/cpp-config-ui.dir/cpp-config-ui.cpp.o' failed
make[2]: *** [examples/CMakeFiles/cpp-config-ui.dir/cpp-config-ui.cpp.o] Error 1
CMakeFiles/Makefile2:420: recipe for target 'examples/CMakeFiles/cpp-config-ui.dir/all' failed
make[1]: *** [examples/CMakeFiles/cpp-config-ui.dir/all] Error 2
Makefile:117: recipe for target 'all' failed
make: *** [all] Error 2
Can anyone help me with this?
Thomas
Thomas
Hi Thomas,
Support for the Realsense SDK is provided by Intel on their forums: https://software.intel.com/en-us/realsense/robotic-development-kit -
I am trying to install the open source library librealsense, provided on github.
I can't use the official SDK. -
The one on github is the RealSense Library officially supported by Intel.
In the list of supported boards there is also UP Board.
I would suggest again to ask on their forums which is where you would find the best support for the RealSense library. -
Ok great, glad they now have support for the open source library.
Thanks for your help!
