Missing UP-board screw mounting information
Henk Ringersma
New Member Posts: 15
in Peripherals
This UP board is very small, I love it, but mounting inside a case without cables sticking out is hard.
Can you please provide information (e.g. at the document section of this website) about the existing screwholes in the bottom baseplate / heatsing of the UP board.
Please provide the template with the measurements between the screwholes as well as the screw-thread to be used.
Thanks in advance
Thanks in advance
As an alternative you guys might add a mounting frame to be sold at your webshop :cheer:
Something like the (fake) pic below? similar as an 2.5" SSD frame into which the UP-board can be mounted?
Hi Henk
we are going to offer soon a metal housing that permits fanless operations until 50 degrees of environmental temperature and VESA 75 and 100.
we hope to be ready in September
In the meantime you could print the plastic housing that we published on the community.
cheers -
Shame!
I can understand you like to sell cases through your webshop (we are all doing business here)
Does the new metal housing have room for an additional 2.5" harddisk drive to be included inside the box?
I use the UP board now as my NAS without a screen, keyboard and mouse. It will be tucked away out of sight too.
A few small openings for airflow are definitely needed . And even a little fan I would not mind as the board is getting hot.
The current board is hard to mount, therefore my request. -
Any progress about the screw sizes and mounting info?
Am I right, that these small 4 screwholes (marked with arrows on pictures) have a metric thread M2.5?
Best regards,
Nic -
Yes, metric 2.5mm is what i used too
HenkR, I'm with you on your quest for info as to where to drill the holes to mount this board. Sure, it would be easy if it was a square pattern as my cnc mill could do that in 10 minute, 7 of them in figuring out how to clamp the cabinet plate to the mills table, with a bit of sacrificial plywood under it. So please, a link to the plate drawings so that those of us with the machining tools can do a quasi-neat job. Thank you if that can be arranged.
- 105 Announcements & News
- 5.5K Product News - New Product/Product Change Notice/ End-of-life
- 353 Welcome Developers!
- 182 Unboxing & Project Sharing
- 13K Tech Updates
- 6.9K UP Products
- 182 UP 7000
- 22 UP Squared i12
- 5.9K UP Xtreme i12
- 34 UP Squared Pro 7000
- 15 UP Element i12 Edge
- 71 UP 4000
- 32 UP Xtreme i11
- 36 UP Squared 6000
- 67 UP Squared Pro
- 174 UP Xtreme
- 847 UP Squared
- 90 UP Core Plus
- 224 UP Core
- 4 UP Xtreme Lite
- 44 UP AI Edge
- 223 Starter Kits & Peripheral
